Need Some Help With Pyrometer Install
Old 05-27-2007 | 05:22 PM
GOT BOOST?'s Avatar
I had the old version dipricol pyro and today am putting in the new optix pyro. After wiring the gauge up it doesn't work, it has light when I turn my lights on. I wired the red wire ( hot wire for guage power) to the same cigarette lighter wire that I tapped for power to my rail guage. What wire did you all use. This is a pain. Thanks, Jay
Old 05-28-2007 | 09:36 AM
XLR8R's Avatar
Well, what do the instructions say?
Old 05-28-2007 | 09:40 AM
trik396's Avatar
If you've got power from that cig lighter wire when key is turned on but the guage still isn't working, I'd say it's a bad guage. Or maybe you blew a fuse if there isn't power... check it out...
Old 05-28-2007 | 10:02 AM
jrussell's Avatar
Check/change your ground!
Old 05-28-2007 | 10:09 AM
Luvnacumns's Avatar
Yep, mine was giving me fits.. Checked the ground wasn't too great changed it.. Wollla!! Good to go!!
Old 05-28-2007 | 10:43 AM
Pooter's Avatar
My cigarette lighter didnt work, I hooked all my guages up, fired it up for the madien voyage only to see nothing move, turned out my cigarette lighter isnt getting power for some reason. I tapped the pink/white tracer under the column, worked great.
Old 05-28-2007 | 07:17 PM
GOT BOOST?'s Avatar
It was a bad ground, thanks guys. Jay
kerry.king
09-03-2015 08:22 PM
StevenAg03
26
02-12-2007 04:55 PM
TinJim
26
09-20-2005 12:58 AM
fordsmasher
07-01-2004 08:01 PM
Push Rod
10-22-2002 11:04 PM
