need quiet muffler
I have a Donaldson M120100 on mine and it's just ever so slightly louder than stock. In fact it's probably not louder, just deeper. It's almost a direct replacement for the stocker too. Just search on M120100 and you'll find some pics here.
I had a Rokktech Silent Might muffler installed about a year and a half ago, and it provides nearly the same as stock noise level. There is slightly more turbo whistle, but inside the cab of the truck you can't tell that I have a high performance muffler. These mufflers are designed specifically for the 6 cylinder Cummins and are tuned to have less back-pressure than a straight pipe between 1600 and 2800 rpm. The muffler has an absolutely straight through unobstructed flow path with four small ports near the rear that open into tuned chambers. They have a web site if you want more info.
If theres a muffler with less backpressure than a str8 pipe i want one 240" in length so i can run it turbo back
Oilburner04
27
01-24-2020 05:41 AM
JW's3Dodges
18
05-30-2010 07:08 AM
Megaramasaur
12-12-2009 07:51 AM
fountain1fan
50
06-13-2008 10:19 AM
zboost
06-16-2005 11:35 AM
