need location of off with key hot wire
Old 04-09-2004 | 05:53 PM
sterke76MD's Avatar
I'm wiring a CB in my '03. I want it to go on when I turn the ignition to accessory or run the truck. Where can I find a hot wire under the dash that goes off when I turn on the ignition/accessory switch? What color is it?
Old 04-09-2004 | 06:08 PM
CUMMINSBILL's Avatar
There are 2 12 volt ignition accessory wires one is GREEN and one is ORANGE they are both in the ignition harness near the steering column under the dash. These are the 2 wires I had to connect my remote starter to to activate the heater/ac controls and they are both key on or key in accessory position hot. Hope this helps.
Old 04-10-2004 | 07:14 AM
Mike_Boutet's Avatar
I ended up running mine hot all the time. I ran it right to the battery. I was getting a little interferance when i ran it thru the trucks wiring.
Old 04-10-2004 | 10:34 AM
Mike67RS's Avatar
The upper cig lighter is a keyed hot. Pull the front dash panel to access it. I run my Sirius off of it...Mike
Old 04-10-2004 | 05:54 PM
CAKUZ's Avatar
Re: need location of off with key hot wire
There is a heavy 12 or 14 gauge Blue wire that goes to a plug in type circuit breaker located above the emergency brake pedal area that is hot W/Ign. It is the Hot wire for the power windows, plenty of juice for CB, etc.
03-HO
06-09-2007 01:50 PM
Festus
14
02-10-2007 10:45 PM
59FORD
04-07-2006 12:28 AM
CStroked
07-07-2005 10:55 AM
TPilaske
16
11-22-2002 08:15 PM
Quick Reply: need location of off with key hot wire
