Need Injectors and Studs B4 MP-8?
Take a look at my Sig guys and help me out. Ive heard that the mp-8 will crack my stock injector nozzels and that i need head studs since im already getting 48-49 psi with juice on 5. If so should i go with 90 horse injectors and which brand?
Also can studs be installed 1 at a time instead of having to pull the head and replace the gasket. thanks
An MP-8 on 50-60% max if you have NO OTHER preesure adders will be the best Stack possible for your Juice. Period.
Studs can be done with the head on...and reuse the original gasket, but you should take the time to pull it off...bottom tap and use a new gasket...do it right...ONCE!
I would stick soem Mileage Flux Injectors while your at it...
Search for my post about them.
hawaiianbro
12-29-2012 10:26 AM
77machomopar
11-30-2009 11:55 PM
lvmknsmoke..
12-05-2008 07:27 PM
RyeThomas
09-29-2006 11:17 PM
