Need help with Transmission temp gauge
Old 02-05-2011 | 06:10 PM
dogcamo's Avatar
I have had the gauge for about 3 years, working great. About 6 months ago it started acting funny. The needle jumps all over the gauge. Deisel Manor told me on 2 occasions it was the amp box. I called Isspro and they sent me a new amp box. That is not the problem, gauge is still doing the same thing. I have already checked all the connections. Anybody have another suggestion of what could be causing the problem. The sending unit is the one that goes where the test port is on the passanger side. Could it be the gauge? It would like to think not.
Thanks Chris
Old 02-05-2011 | 06:55 PM
madhat's Avatar
Administrator/Jarhead
Check your connections at the box, my ground wire came loose one time, and the gauge was going nuts.
Old 02-07-2011 | 08:07 AM
no_6_oh_no's Avatar
Are you sure the probe is not beat up from having it in a test port and hitting the servo?
Old 02-07-2011 | 08:36 AM
soulezoo's Avatar
DTR 1st Sergeant
x2^^^
I learned this the hard way.
Old 02-08-2011 | 05:15 PM
dogcamo's Avatar
Checked the ground wire no issues there. I think I'm going to move the sender from the test port to the tranny line on the drivers side.
Old 02-08-2011 | 05:30 PM
dogcamo's Avatar
Does anybody have this for their tranny gauge "Transcender Temperature Adapter" from Diesel Manor? Does it read accurate?
Old 02-08-2011 | 05:55 PM
NavyDood's Avatar
It does pretty good actually. It isn't as responsive as in the line, but much better than a test port or in the pan.
Old 02-08-2011 | 06:44 PM
no_6_oh_no's Avatar
ISSPRO should be a 2 wire and does not need a ground, at least the ones I have used are.
Again, check the probe and make sure the servo has not been beating on it, if you can get it out.
Old 02-08-2011 | 09:49 PM
VaultRam's Avatar
I had the same problem a year ago. I also got mine from Diesel Manor, called them and they sent me a new box and temp sender. That fixed it but I do have the sender in the hot line.
Old 02-09-2011 | 04:16 AM
madhat's Avatar
FYI, mine does. I know the vary from model to model. Mine are old, tho. Some EV's from 04...
Old 02-09-2011 | 10:26 AM
Shanajustin's Avatar
I guess I just got lucky. Mine started jumping all over the dial a couple of weeks ago. Crawled under to take a look at the white molded connector at the sender. Pulled it apart and cleaned it, fixed it right up. Best of luck.
mar67655
03-21-2009 05:35 AM
ngkefalides
0
08-12-2008 08:33 PM
MPowell800
08-19-2004 01:16 AM
Pickle
04-17-2004 01:17 PM
Pickle
02-10-2004 09:19 AM
Quick Reply: Need help with Transmission temp gauge
