Need Help with HID Lights
You need to install a 6 ohm 50 watt resistor on the low beam wire to a good ground on each side. The control module is not sensing enough of a draw and is turning the power off. You can find these on ebay as LED load resistors.
Wow have no clue how to do that where can i get that done at?
Check you hidspeed.com you probably need their "special harness" for the H13, they also have a trouble shoot page. The special harness eliminates cutting and splicing to add resistors. Do you also have the "lamp out" in the odometer?
Could I splice the ground on each side? if not what color were the wires for the low beams
I used a 3-4 ohm 100 watt resistor on each side. Works great with no lamp out light. www.mouser.com
carte89
01-21-2010 12:38 AM
Cummins610
02-16-2009 05:59 PM
IntakeRacing
10-21-2007 04:51 PM
