Need Help Fuel Pressure Seems Low
Here lately my truck doesn't seem to be running all that good. I have the BD outlook monitor so I viewed the Injection Control Pressure setting. At idle it says about 6300-6400psi at WOT on crazy larry it goes no more than 18500psi. But it will only go to 18500psi on all the settings.
Need help are these numbers about right or is the outlook a reliable gauge at all.
Also I have all stock fueling system. Thinking my lift pump is gone or going.
I think that rp is definately low....i can hit 25000 psi with my setup....no fuel pump yet...at idle i'm at 8-9k in park, 9-10k in drive stopped....using quad rp guage and i believe these are normal numbers with a programmer / box...they're definately norm for smarty beta users.
I would think lp may need replacing....either way, it's good to have esp if your running cl.
JThiessen
16
08-22-2009 02:46 PM
bc3
12-01-2007 10:19 PM
tanderson2002us
06-20-2006 04:21 PM
