need help error P0148 and P2509
I have had my dodge diesel 04.5 5.9 stock except air dog installed 6 months ago. The problem I am having is that it will idle fine but when accellerating after about 10 min it will stall out. I have had it in 3 shops the last is the *********** which scanned it and told me I needed a cp3 pump and possibly FAC or a fuel limiting valve. It was doing the same thing 6 months ago and the reason for the air dog lift pump. If I am correct the P2509 is a dead battery which could be possible cause had to jump it after not running for 2 months. Could the other code really be the cp3. I am obviously not going to pay the 2700 clams the dealership wants for the part, but before I but a replacement part I want to make sure I am not throwing good money after bad. I have noticed more smoke before it stalls. Thought for sure the dealership was going to tell me I needed injectors. That probably would be next.
Change the FCA, fuel control actuator, before any other major repairs. What you might try is dose the tank heavy with Power Service and 2 stroke oil. The FCA's will jam and cause problems especially if they sit for a while and not get run.
Could also be a bad rail pressure sensor but they are not as touchy as the FCA.
It could be the CP-3 but I would definitely do a lot more testing and research before dropping the $$ on it.
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
2509
Case Number K24612402
Vehicle Issue MIL. P2509. The engine may stumble or stall out.;12 volt power (unswitched) and the ground circuits to the ECM are good. Batteries and charging system operation are good. If applicable (2006 and 2007 MY trucks), the ECM has already been updated per TSB 18-001-07.
System or Component Die out / Stall,Hesitation / Sag / Stumble;DTC / Error Message;ECM
Recommendation If the problem can be duplicated, disconnect the fan clutch 6-way connector and check if the concern still occurs. If the problem no longer occurs, replace the fan clutch assembly.
Modification Date 01/04/08 9:57 AM
another case
Case Number K65001956
Vehicle Issue Engine Dies At about 2,200 RPM While Driving. Set Codes P2509, P0113, And P0628. Code P0628 Resets. Verify Fuel Lift Pump Operation.;Engine dies out while driving. Mil is on and codes P0113, P0628, and P2509 have set. Codes P0628 Keeps resetting. The vehicles charging system and batteries check ok. ECM and PCM power feeds and grounds are ok. Fuel quality is good.
System or Component Long Crank During Restart,Restarts Immediately - Runs Fine;Customer Concern (No DTCs),DTC / Error Message;Wiring,Battery,Charging System,Malfunction Indicator Light / MIL / Check Engine Light,Fuel Pump / Transfer Pump;1500 to 2000,2000 to 3000;Light Throttle,Moderate Throttle;Acceleration;Yes - Intermittent,Yes - Continuously;Fuel Pressure Low,Fuel Volume Low
Recommendation Verify fuel volume. For test procedures refer to the 2003 Powertrain Diagnostic Manual Page 260. Use a test light or a head light to load test the transfer pump power and ground. Inspect the transfer pump connector pins and crimps. If ok replace the transfer pump.
Modification Date 04/13/04 9:03 AM
another case
Case Number K19621710
Vehicle Issue The Engine Stalls While Driving And Does Not Restart. Setting Code P2509. Verify ECM operation.;The engine stalls while driving and will not restart. Code p2509 is setting. The charging system and batteries test ok. Fuel volume and quality is ok.
System or Component Will not Restart,Engine Cranks;Customer Concern (No DTCs),DTC / Error Message;ECM,Starting System;Cold Start (After 8 hour Soak),During Warm Up,Normal Operating Temperature;Yes - Intermittent,Yes - Continuously
Recommendation Refer to the appropriate Powertrain Diagnostic manual and perform diagnostics for code p2509. Fabricate a test light using a headlight and jumper wires. Load test the ECM battery feeds, ECM grounds and ECM switched ignition using the headlight. Check the engine ground on the engine block located near the fuel filter. If the ECM power feeds and grounds check ok replace the ECM.
Modification Date 04/19/04 11:32 AM
another case
Case Number K13878564
Vehicle Issue Engine Stalls Out. 'NO BUS' Message Is Displayed. P1652.;Power and ground connections to the Cummins ECM are good. P1652 and P2509 are set.
System or Component Die out / Stall;DTC / Error Message;Electronic Control Module,ECM;Yes - Intermittent,Yes - Continuously
Recommendation Inspect the wiring harness near the C108 (14 pin) connector. This connector should be at the back of the engine, near the transmission bell housing.
Modification Date 03/17/05 4:25 PM
another case
Case Number K11967108
Vehicle Issue Engine Dies While Driving. Code p2509 Sets.;Engine dies out while driving. Mil is on and code P2509 has set. Fuel transfer pump volume is low. For test procedures refer to the 2003 Powertrain Diagnostic Manual Page 260.
System or Component Long Crank During Restart,Restarts Immediately - Runs Fine;Customer Concern (No DTCs),DTC / Error Message;Wiring,Battery,Charging System,Malfunction Indicator Light / MIL / Check Engine Light,Fuel Pump / Transfer Pump;Target Idle to 1500,1500 to 2000,2000 to 3000;Light Throttle,Moderate Throttle;Acceleration;Yes - Intermittent,Yes - Continuously;Fuel Pressure Low,Fuel Volume Low
Recommendation Perform diagnostics for code p2509. Load test the batteries and charging system. Clean tighten the ECM, fuel transfer pump ground stud on the engine block located near the fuel filter.
Modification Date 04/13/04 9:40 AM
another case
another case
another case
another case
LFD2037
21
09-05-2021 10:28 PM
DMS1707
09-01-2017 11:41 AM
cowboydan84
11-26-2007 01:09 PM
RACER47
01-03-2007 08:21 PM
