need help with egts
need help with egts
i have a 04 cummins predator tuner 90hp injectors head studs full billet ats trans ats trans controller 5'' turbo back fas 150 fuel system, cold air intake
but heres my problem im hitting 1600-1700 egts when i lay into my truck on extreme mode i know i need to junk that stock turbo but do i have any other options first
DTR 1st Sergeant
First, do NOT do that again! You may have already trashed your motor. You have no business with 90hp stix and a tuner with the stock turbo... especially that stock turbo. With the 03-04 engines, they have weak pressed in valve seats that are prone to drop out and trash a whole motor with egts sustained over 1400. As high as you were, you may have even melted pistons. You may not even see symptoms of this for a while before it lets go. You may have gotten lucky though...
Sorry to scold you like that, but someone has to throw the cold water on your head before you ruin your engine if you have not done so already. You are really playing with fire. literally.
sabreson
26
09-24-2010 01:54 PM
97dodgeram2500
15
04-14-2009 05:40 PM
Diesel97
15
06-30-2007 08:34 AM
Rockyhud
16
04-27-2005 07:51 PM
