Need better instuctions for hooking up Outlook monitor
The directions that come with the outlook are pathetic it does not tell you where to hook the red conector that is on the harness that conects to the pyro or where to hook the yellow wire that is on the OBD conector. Any help would be greatly apreciated.
If you are talking about the red and yellow pyro leads they hook up long to short and short to long. Don't worry about colors. Hook the short pyro lead up to the long lead of pyro 1 from the monitor. Hook the long pyro lead up to the short lead of pyro 1 from the monitor.
The long yellow wire goes to the fuse box and taps into fuse 28. The little red connector is only used if you are hooking up a module box. Sorry if this is confusing. I hooked mine up this way while on the phone with Bully Dog. Let me know if this isn't clear.
Todd
Todd
Thanks I new how to hook the pyro leads just didnt know what the red plug was for and where to hook the yellow wire but I got it all hooked up and is working fine.
ihatesparkplugs
12-17-2008 09:32 PM
wap
15
03-21-2006 11:48 PM
