Need Advice for Upgrades
Based on my signature, I'm not really to sure whats the next upgrade to add that supports my setup. Ultimately I want a good towing machine, hopefully between 500-550hp, I don't get into boosted launches, racing or sled pulling. The truck is considered a daily driver, but I want something that is fun to drive as well. I'm open to all opinions....thanks...
turbo and exst manfold will help with your towing in the turbo spool up i run a silver 62 gen 3 and love it spools up quick and with my other mods the truck is a beast when it needs to be
Actually I did hit the dyno already before I installed the HTB2, I was at 430hp/862 running the Diablo Puc/Predator Stack (Extreme mode non rkl). I like the Triple Dog better but I don't feel the same HP from it, I'm hoping they come up with some more pressure.
Your welcome! Wish I had the money 'cause I'd get your turbo and a set of Flux 1 injectors. Those are going to be my final power enhancing mods.
I have to say I do like this turbo, after reading a whole lot and talking to a guy in my area here, he said he's tried a few different turbo's but went back to the HTB2, it spooled the best and was a good pulling turbo...
Yep running the Crazy Larry now, with low end turned on, I noticed in the mid to high range things kind of flattened out under full throttle (60-80mph), so I turn TM of and that seemed to take care of that. I'm just a little nervous to run with no TM all the time.
A dual feed line And an mp-8 will get you to your mark and will bee good fueling for towing. That 62-12 you have will definatly get hot thow. I would look into getting getting a 62-14 or 62-13ss because high tech will take care of you. Keep in mind that around 500-550hp the cooling system starts to have a hard time keeping up. My turbo actually works great for towing and never really gets hot.
What you need,... IMO
1) A SMARTY BETA or equivalent power (I like the 4.2 best)
2) Lose your lift pump and get a Mitusa, FASS or GDP.
3) Lose your turbo for upgade to a 64/71/13 SS
4) Get a quality intake
5) Your stock cp3 will get you there fine.
That will put you at the top end of your goal and you'll be able to tow like crazy.
Nightowl
03-04-2009 09:58 AM
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 10:15 AM
Blackbomb77
04-02-2007 06:53 PM
kev94mx
12-05-2005 03:39 PM
