My Walbro fuel pump setup
Old 02-18-2006, 05:07 PM
slim51015's Avatar
Originally Posted by JStieger
if I can use a Walbro instead with a suitable regulated bypass then I'll have a pump in the Walbro that is not running at 100% 100% of the time. .
That sums it up right there.^^^
Keep us posted on your install.
Old 02-19-2006, 07:28 PM
trik396's Avatar
Update
After installing a 5/16" bypass, I'm finally satisfied with the pressures I'm seeing. At warm idle pressure at the cp3 is 23psi. At 65mph I have 20psi at the cp3. And at wot (90mph was all conditions allowed) cp3 had 12psi. This is with my mildly modded truck. It's all good
Old 02-19-2006, 07:30 PM
Geico266's Avatar
Sweet! Good job trik.
Old 02-20-2006, 12:40 AM
SafeHarbor's Avatar
Hi, Trik,
Here's something I still don't understand. If you had elected to use an inline regulator around the CP, would that make the pressure the same from idle to WOT, assuming the pump can push that?
Or, in other words, is it the bypass that's causing the relatively low FP at WOT?
Thanks.
Old 02-20-2006, 04:26 AM
2500CTD's Avatar
The Walbro is supplying enough fuel the the return line & the CP3 is being fed enough fuel to cause a back pressure that Trik is saying he has. At WOT the CP3 is using more fuel at thus the drop in FP. A seperate return line, and a reg that can withstand the high flow, press of the Walbro, would keep the FP more consistant. The reg would do best if mounted right before the CP3. I have a 2nd gen but I'm needing to redo my FP as well. I was looking at the walbro a while ago, but a supplier of them said they would not work with diesel. Obviously they will.
Old 02-20-2006, 07:46 AM
trik396's Avatar
If I wanted/needed a more constant psi, I would install a regulator. My current fuel needs don't require that expense. As already stated, the Walbro can push over 100psi, so that isn't the issue.
12psi at wot is more than double, almost triple what I was seeing with the stock lift pump. I'm very happy with the current setup ...
Old 02-20-2006, 09:50 PM
larryt's Avatar
Good Work!
Trik
Thanks for the writeup and glad it worked so well.
Did you end up using a strainer pre-pump?
Sure would like to see a bunch of pics.................please?
Did you use the 392 pump? nevermind, just checked your link I noticed
they are out for now.
I'm pretty sure I'm going to do something similar within a few months. Thanks
to guys like you that are doing the groundwork.
Larry
Old 02-20-2006, 10:40 PM
trik396's Avatar
No strainer/filter pre-pump. I'm going to add a 2micron filter after the stock 10micron. I used the 392 and there are other places to buy them, just not as cheap. I've got alot of pics, just haven't posted them here yet. Some are on another site. I'll get around to putting them on here someday soon...
Old 02-20-2006, 11:44 PM
larryt's Avatar
Ok,
Thanks much
Old 02-23-2006, 10:02 AM
davelinde's Avatar
Originally Posted by streetsmoker
Another thing SD, you would not believe the # of people I run accross that do not know about the huge problems the 98.5-04.5 Cummins lift pumps are having. I have talked to 3diff. people in as many weeks with 3rd gens that have the dreded CP3 weep and their deelers didn't tell them it could be caused by the LP. As far as a lot of the dealers are concerned, the problems were fixed with the advent of the 3rd gen.
Add me to the list of those who didn't know. I'd read some of outright LP failures - a lot seemed to be in Canada...
I'm about to get my third CP3 installed and I talked to the dealer about the possibility of the LP causing it. The mechanic said that was a 2nd gen problem for sure but he didn't know about any other 3rd gens having it. I don't know what the Service Writer thinks - I'd guess they'll only do what STARS tells them. I've got 2 more years on the warranty of the latest CP3...
Old 02-23-2006, 11:11 AM
B.Law's Avatar
What about pre-fuel filter pressures? Do you plan on monitering them to make sure you don't get any cracked lids?
BTW I can't find any 5/16" ID hose for the friggen bypass anywhere, well not rated for this application anyway...Where did you come across some? I may just have to go with the 3/8" I have on hand...
Old 02-23-2006, 11:29 AM
trik396's Avatar
You could monitor pre filter pressure. I'm not currently doing that. I've got anywhere from 20-23psi at cp3, figuring 5or6psi for line and filter restriction, I'd guess I have 25-29psi at the filter. I've had higher and no problems.
I got my fuel line from PepBoys which is a large auto parts chain in my area. 5/16" fuel injection line. Paid like $4 for 18".
12valve
25
11-26-2009 12:52 PM
madhat
06-01-2008 09:03 PM
CRXsi
08-01-2007 06:55 PM
Mt.Hckbry
02-04-2007 10:06 PM
piperca
08-27-2006 09:51 PM
Quick Reply: My Walbro fuel pump setup
