My Walbro fuel pump setup
Old 02-17-2006, 02:46 PM
trik396's Avatar
I've been getting questions about this so I thought I'd just start a new post here.
I mounted my Walbro on the inside frame, just behind the transfer case and ahead of the crossmember. This is on a short box truck. I used the mounting straps included with the pump. I installed a new pickup tube that I purchased from Rip. It's the same one used on the fass. From that pickup, I ran a 3/8" fuel line and fed the Walbro. I ran a short piece of line out of the Walbro and connected this to the stock fuel line that I cut with a tubing cutter. I clamped a short piece of hose to the existing line from the tank and plugged it shut. I'll get into why I did this later. At my cp3 inlet and return outlet, I installed 2 tapped banjo fittings from Geno's garage. I installed 2 barbed fittings at these locations. One 5/16" one 3/16". The 5/16" on the inlet, I ran a 5/16" fuel line toward the driver fender between the washer fluid and the fuse panel. Here I mounted a "tee" fitting" and connected the 5/16" line. One other port of the T is where I installed a pressure sender unit. The other port is where I reduced down to the 3/16" barb and ran a fuel line connecting it back to the cp3 return w/ barbed fitting. Very simple. I bought a Painless wiring harness/relay from Summit and installed it on the fender near the firewall. I trigger that relay with a tap off of the cigarette lighter fuse in the panel (it is hot when the key is on) so this will energize the pump and de-energize the pump with your ignition key. I ran the hot lead of the relay to a fuseholder and went directly to the + battery terminal. I also removed the stock fuel pump relay (61). The load side of the new relay I ran down to the frame (with loom) and wired to the walbro. I grounded the walbro to the frame as well. Between the pump, banjos, barb fittings, hose, wiring, loom, various clamps and wire connectors plus the fuel pickup, I have about $210-220 invested.
As it stands, I cannot see how any other system could stack up against this for the power, performance, and durability (time will tell), AND the low, low price. There will be those out there who disagree.... This is America (for most of us) and that is fine. This is my opinion, backed up by numbers, and performance.
btw- the reason I ran the seperate fuel pickup is IN CASE my pump dies, I can switch back to the stock in tank pump in 5 minutes by switching the 2 clamped lines under the truck and installing the stock relay back into the fuse panel. I don't know of any systems that allow that type of redundancy, at that price.
Old 02-17-2006, 03:15 PM
metal_miner's Avatar
Excellent job! What's your fuel pressure with the 3/16" bypass versus 5/16" bypass? I think the factory steel return lines were 5/16" (3/8" OD) the last time I measured them???
Old 02-17-2006, 03:22 PM
streetsmoker's Avatar
Hey Trick, good going. I will be doing this soon. I still have the factory original canister mounted unit w/125,000+mi. and though it still gives good pressure, when I have both my BDPP & Edge tuned up I can tell it's starving for fuel, so I don't know how much longer it will last. So I just keep things duned down and try to drive sane . I can't say much, but a member of both here and TDR is working on a retrofit kit with all nessesary fittings and I'm going to wait till he has them together, cause I don't have the time to fab up my own or the cash to pay someone to do it for me.
Old 02-17-2006, 03:27 PM
Geico266's Avatar
Now that is a great idea. Putting togeather a kit for the different CTD applications is what is needed.
Good job, who ever it is.
Old 02-17-2006, 03:42 PM
JCROMAN's Avatar
Sounds nice.....I like the fact of having the extra pump still intact in case the other goes out. I was thinking why not put a Tee inline after the Walbro and put a 1 way valve on it then you could leave the stock lift pump always hooked up and just pull the fuse. then it would be a plug and play switch over.
Old 02-17-2006, 04:46 PM
trik396's Avatar
Jcroman - Now that's a good idea also. Wish I'd thought of it while I was under the truck.
Jsteiger - I've been playing around with different size bypasses and a totally seperate 3/8" return line. Currently I'm running the 3/16" bypass but my pressures are a little too high, from 24-28psi warm while cruising.
With the 3/8" seperate return and no bypass at the cp3, I was at 17psi cruising, but at wot, it'd drop to almost 3psi. So I'm looking for a medium ground in between. Probably going with 5/16 or 3/8" bypass at the cp3. I'm still experimenting as I think I'm the only one with an 05'Dodge messing with this stuff.
Whatever the pressure, so far, it has run without a hiccup.
Old 02-17-2006, 04:54 PM
Superduty's Avatar
"Good job, who ever it is."
It isn't me (Superduty) if that is what you are implying. I don't have a membership at TDR either. I think Gypsyman is doing something but you would have to ask him to be sure.
Old 02-17-2006, 08:41 PM
No, it's not Superduty. MAn can you think of the stink that would raise with some folks on here. It is Gypsyman, but we need to keep it quite as possible until he can get an advertiser's spot or he will be violating some major rules by telling people. so there will be no more word about it will there. We don't want to ruin a good thing before it gets off the ground. Glad to see you back Superduty, were you muted for a while or just been busy? And to think I almost went to BD Diesels retrofit kit which I found out was one of SD's glorified carb pumps. They couldn't even tell me how to get a replacement w/o all the fittings if I needed it. I just hope my stock setup lasts till I can get my Walbro installed. Another thing SD, you would not believe the # of people I run accross that do not know about the huge problems the 98.5-04.5 Cummins lift pumps are having. I have talked to 3diff. people in as many weeks with 3rd gens that have the dreded CP3 weep and their deelers didn't tell them it could be caused by the LP. As far as a lot of the dealers are concerned, the problems were fixed with the advent of the 3rd gen.
Old 02-17-2006, 08:45 PM
Geico266's Avatar
That is a great idea! Now work on an incab switching device. Acually, most airplanes have two fuel pumps so pumbing would be a breeze. Just use aircraft stuff.
Old 02-17-2006, 09:11 PM
trik396's Avatar
You could probably set up the stock relay/pump with an in cab switch. You could also use some type of electric solenoid valve to switch fuel from one line to another. All from in the cab, with the engine running. Cool.
Old 02-18-2006, 12:20 AM
TexasCTD's Avatar
Thanks Trik for sharing this stuff. Sounds great. Still a little over my head, but im catching on.
It would be nice if Gypsyman could get this kit together.
Trik.....Not asking for a price....but where did you get your Wallbro pump? Link? Thanks for your help and I got your PM.
Old 02-18-2006, 07:44 AM
trik396's Avatar
Here ya go. Least expensive I've found.
http://cgi.ebay.com/ebaymotors/ws/eB..._BIN_Stores_IT
Old 02-18-2006, 08:51 AM
tristan21's Avatar
Whos Rip? Sorry I missed that one. Did a search came up with nuthin.
Old 02-18-2006, 09:02 AM
trik396's Avatar
Rip at Sourceautomotive.biz
Old 02-18-2006, 03:31 PM
Thanks for the link - I just picked one up! I am going to plumb it in with a Racor filter. I was going to do a Holley - Racor setup like a FASS mounted right near the tank, but if I can use a Walbro instead with a suitable regulated bypass then I'll have a pump in the Walbro that is not running at 100% 100% of the time. I've had my Holley (ala Scotty Smartfuel setup) and so far so good at ~20,000 miles. I just wish I didn't have the stupid APPS in the way. The way that Superduty has the CAT filter mounted is perfect after the stock canister and it's a clean installation.
Quick Reply: My Walbro fuel pump setup
