my input on the Revo 5.3
#61
I thought it was a great Smarty improvement, not needing a computer to make the adjustments. No it's not on the fly, but it's not 45 mins on the computer either.
#62
A run in the 1/4 will bury the gauge by half track but, once I hit 3rd they start to drop.
For a 5 second dyno run and a 12 second track run.... it does fine
#63
That's what you do!
Step 1: Turn key on and plug in Smarty
Step 2: Adjust options (such as RP, timing, TM, etc.) in the menu
Step 3: Smarty will write those options to it's memory
Step 4: Choose your Catcher # and begin programming (your recently chosen options will be included in that Catcher update)
#64
I ran the beta 4.2 every time I was at a track and it did as well as this new software without worrying about changing a thing.
I see no point in storing anything for the next change. If I were to load a different catcher software, I'd just change those settings then
Bully Dog can do it.... I don't see why the Smarty can't
#65
well just call me confused and a . I have no idea what I used at the track or on the dyno then.
As I said, if you still have to take the 10 minutes to upload another catcher software..... you might as well just change your settings then.
If I ran down the track and realize I want more timing, I would have to reload the whole program again ??? that doesn't make sense..... again, I see no point to storing to memory.
It oviously was my imagination then when I changed going down the road but, I took everything to default and the truck acted like it was on default without the added parameters. Totally different than when at the track
#66
You're overthinking the whole thing. Have another cup of coffee and sit back and think about it man.
#67
There are still standard tunes available on Mads site. You're not forced to use the Revo. Even with the Revo you don't have to change any options if you don't want to. You can simply plug it in and update using the default settings for each option.
.and that's exactly what you're doing! The Smarty has to "remember" your option settings somehow. Like I said, it doesn't matter if the next ECM update is in 10 seconds or in 10 days.
The beta's weren't adjustable but, with their preset parameter always did my truck right.
#68
I understand what you're saying and suppose you're right but, in my mind.... it's pointless. It's suppose to be a race tune ( the " R " anyway ) and what a pain in the butt to have to make a run, decide you want to try more timing so, you have to spend another 10 minutes loading just to realize you needed less timing.... there's another 10 minutes.
Tuning a truck is not always fun, but once you find what works best for your mods/application then it's all downhill from there.
#69
here's how I'm looking at this. The " R " is for me, a tune for the track. When at the track, I want to most powerful tune I can have which in this case is level #9... that's it. Not #8 or #7
So, if I want to change any of those parameter, I have to spend all night reloading level #9
get what I'm saying..... if I spent a night at the track and wanted to try 8 different parameters, that's 80 minutes spent loading software when I could be making runs down the track ?
#70
If so, those are readily available in the Beta 4.X, 4.11 on Mads site, and even Revo TNT/R using the default options.
I just don't see why the added adjustability is really a concern? You only have to wait that 10 minutes if you want to play with the options.
#71
I completely understand what you're saying and wish it wasn't that way, but would you rather have a program with NO adjustable options at all?
I did net some higher hp numbers but, not a lot. The number in my sig is the corrected number. Uncorrected is very close to what I already have with the 4.2
Guess the theory behind it is it's a all in one software.
#72
Well, maybe if I see a real change from past softwares when changing things... it may be worth it but, as I said... the 4.2 didn't need adjusting as it was ***** to the wall at the track. I will say this tune is a bit smoother.
I'd like to know how it does in the 1/4 mile. Your 1/8 mile time is about the same as mine (8.0xx), but your speed is MUCH faster. I'm only going about 85mph in the 1/8th.
What was your 1/8 mile time and speed with 4.2?
#73
triton...
Just load SW9 TNTR and leave all on default except 4k rpms...
I bet you will be happy then. If you need to dial in some parameter...change it after. It only takes seconds...not minutes.
#74
I didn't say I wasn't happy just I think it's kind pointless to have to reload the same level over and over just to change parameters.
I also know we can't have it all and this is getting closer than anything was to being adjustable
