MPI Twins pics and write up
I dont know if the 400 is upgradeable to the 480 but I know the 480 is quite a bit more expensive than the 74mm 400. Or at least that is what I was told.
You can, but you run into problems trying to force so much air through the compressor on the stocker-- also, with the kind of fuel needed to spin the s480, you'll end up with too much back pressure on the stock exhaust housing. Anyway, that's the way I see it and could be wrong. These twins have to kinda go hand in hand to a degree.
does anybody know FORSURE if the S400 can be upgraded to S480
Especially after I spent most of the morning on the phone with Don Thuren building a suspension!!!
I think I can make it....
That can be negotiated!!!!
Let me know how your first oil change goes. On mine, the drain from the primary charger is very tight to remove from the block. Since its an aeroquip fitting, I can't be too aggressive with it. So, I had to snake the filter through the cold pipes.
Just something to consider in the future.
LOl.... Me too... oil changes are definately a challenge....
Dwitt0187
38
11-08-2008 01:55 PM
jrussell
102
08-04-2008 12:05 PM
RyeThomas
21
09-29-2007 02:14 AM
