MPI Twins Are In!!! (Pics Inside)
#62
For controlling max boost, yes.
For controlling drive pressures, no.
WG'ing the bottom charger (in the case of an S400) would require using an external WG. That's not cheap and adds a good amount to the price. I think the only time you would really need a WG on the bottom charger is if you're heavily fueled with huge HP.
#64
So what should the top charger wastegate be set up? A htt 62 is whats gonna be on top. Also Say if I wanted to run more then 40psi or limit how much boost I want to run max then what should I do that make that work?
#65
It actually works better IMHO if you do it MPI's way...and the wastegate is actually controlled by a spring resisting drive pressure. Boost is what would be measured in the cold pipe between the the two turbos...
by 40 psi (total boost) you should see near 50/50 split. 40 total...20 in the cold pipe. That menas each turbo is making 20 psi boost. Mine match by 40 and climb almost identical till 80. THAT...is a perfect design.
#66
what is done with the stocker and the wastegate. It is electronically controlled right? What keeps it from overspeeding with the s-400 pushing it? Does MPI provide some kind of an electronic unit to prevent the top turbo from working too hard?
#67
You don't have to worry about overspeeding the top turbo because it's actually working much less than it would be if used as a single. You don't have to worry about overspeeding the S400 because it's such a big turbo with a huge exhaust housing.
Like Christian said, each turbo should be putting out 50% of the total boost. 50psi of boost on a properly tuned setup would mean each turbo is putting out around 25psi.
#68
Ok so what is the correct safe way to go about this? Using a HTT 62/71 on top. Depending on how much total boost I want to run depends on what I set the top turbo waste gate to? For the s400 do I need to put one or two blow off valves in the intercooler pipe? Do both of them work for just the s400? Also how does the blow off valves work, by spring tension?
#69
Total boost is not controlled by the top turbo's WG. Total boost will be controlled by either your max fueling or whatever you have the pop-off valves set at. The top turbo's WG is only adjusted for tuning purposes (to hit that 50/50 ratio which is the sweet spot).
I would say you need 2 or more pop-off valves. They would be relieving boost pressure from both turbos since they're in the pipe leading to the IC.
#70
Yes, they work by spring tension.
#71
To tune for that 50/50 ratio you connect a 2nd boost gauge to the port in the cold piping (between the two turbos). When that 2nd gauge reads 50% of what the total boost is then you're all set. This is adjusted using the WG on the top turbo.
#73
The only time max boost would be a concern is if you don't have head studs or you are way over-fueled with a smaller set of twins.
#74
Ok gotcha.. So pretty much you just need to play with it alot and start off with the blow off valves..
#75
