mpi twinns
mpi twinns
I am probably going to go ahead an get some MPI Twins , Nathans 700hp Set, was wondering how they would run with stock injectors and Stock CP3 for awhile until i replenish Trucks funds . What would top hp be. running Hot Juice stacked with EZ, Walbro System , AFE-2 , ATS Exhaust , Silverline
490-520 is my guess. What you need to realize is that twins won't give you much extra power if you're not currently overfueled - and you're not. I did 475hp with Hot Juice and xzt and 502hp with Hot Juice and mp-8. The ez should be somewhere in between and then maybe an additional 20hp with the twins.
Too many things missing to make big HP
So is there a goal in mind?
Twins
I like the faster spool up and egt Temps along with the ability to have 700-plus HP Set-up , I probably will Run it Stock And then Add Some Flux-2 injectors And a Twin CP3 fueling set-up next year , I figure I should be able to have 580-600-HP with just the MPI Twins Stock CP3 , A Walbro Fuel lift Pump System , Hellman intercooler , probably going to Run a Smarty and MP8 With the Twins.
AFE-2 , ATS Exhaust Manifold , CNC Heater Block , going to be listing this silver-62--74--14 forsale here shortly has roughly 5,000 K. So 700- would be my goal but I will Cruise it @ the 600- HP Level for a year , And some Flux-2 injectors along with another stock cp3 , as prices seem to be dropping as more competition enters the market place. Studs will be done upon Turbo install.
I think you could still run a 62/71/13ss / S400 on stock cp3 & stock injectors for a while until you get some more cash to upgrade to the much needed dual cp3s, fluxs & head studs
the stock single cp3 will be more of a pita , then the stock injectors
a dual cp3 kit & some 1.5 fluxs would be killer with that setup
you don't need big injectors to get 700 rwhp
too much black smoke will eventually lead to the demise & extermination of fast heavy fueled diesel trucks on the streets & highways !
I made 617 and my fuel pressure never moved from 20psi with Walbro. If properly plumbed, I don't see a problem making quite a bit more power with the little pump.
He might not be looking for "big" power. I'm doing twins soon and I'm not going for anything over 650hp. I just want the best 650hp I can achieve. He obviously needs more than what he's got for 650hp, but he never stated a goal, just asked for an estimate.
Fuel psi
Also Omaharam, the original question on this thread was addressing a 700hp set of twins!!! That's not big power??
Pressure is one thing and volume is another. There are guys making big power with a walbro but they're using (2) walbros. Also don't be confused with a max 3 sec run on a dyno with the 1/4 mile. A lot of setups are for dyno strickly and won't cut it on the 1/4. FYI
As for the question..if you go back he makes a couple statements. One stating that he is going to be getting a set of twins that supports 700hp. He never said it was or wasn't his goal. But he did ask ONLY ONE question. What would top HP be with that set up with the fueling he has and I don't think my answer was too far off. As far as 700hp, if that's his goal, I have no idea if the walbro is adequate. But I can tell you it supports 600hp very nicely.
With the PPE twin pumps I needed to add a second Walbro to keep up both volume and pressure. Since the PPE kits do not like more than 20psi feed pressure you cannot get a head start by sending 40psi to the pump.
The second Walbro is on a toggle.
However, you do not need dual pumps for 700hp and no one was talking dual pumps.
I may be wrong but, I think I saw Lloyd Mills make 730 on
a floor it stage 2 & a single walbro.
I think he found its limitations that day.
He has since gone to twin cp3
's & dual walbros.
's & dual walbros.
