More pressure/ boost
Hey guys,
My truck is up and running great now I was wondering if I should see more rail pressure than I'm seeing. I see around 5000psi at idle and I see 15-16,000 hittin it pretty good and 21,000 psi max. Also what mod do I do to my turbo to get more boost. I see 30 pds max. I think I probably just need to lock my waste gate close some how.
Thanks guys,
Topper
Thanks guys,
Topper
on my 2003 i loosened the wastegate and put shims under it,this along with a boost elbow(the kind you get from edge with the ez)will raise the boost level 8-10 psi
