more bully dog probs...pyro reading
ive been through two triple dog setups now and this one seems to work ok. i originally had my pyro, POST turbo and the readings were all over the place and when i got on it, the readings would DROP into the low 100's then spike for a quick second. so yesterday i mounted the pyro pre turbo, in the runner between the #3 and #4 cylinders. while i get a higher spike temp, still running down the highway at 1700 rpms, the temps run at 330-350, if i get into the throttle more than halfway from this point, the reading goes back into the 100's then it jumps to 900-1000. AND i have a BHAF and 5" straight pipe. with the triple on extreme it said i hit 1500* last night WOT on a flat road. does this sound right? its set to defuel at 1250, so why did it keep fueling and climb that high? AHHHHHHH....
Shane
this is my 3rd pyro probe now in the quest to solve my problems. the power i get with it is only good if i wind it up to 2800 then it takes off like a greased pig. until then, its nothing special. hardly ANY smoke at all, period. maybe my truck is just a pile if like to find someone with another comparable chip and hook it up for an hour or two to see if im just wanting too much from a chip or if this isnt workin period. like ive said before, with the LOW power option on, the power is exactly what i am lookin for, but my tranny cant decide how or when to shift.
6speedcowboy
11-04-2013 06:52 AM
Redbeard
01-03-2008 09:19 PM
Luvnacumns
0
06-04-2006 02:21 PM
