moog adjustable ball joints
just replaced my entire front end, which included moog adjustable ball joints. i obviously need a front end alignment now. anybody have these ball joints and the specs needed to get a perfect alignment??
I have them and when I took it in for alignment they were perfect .... no further adjustment other than how they were shipped. Someone will chime in with what they recommend for degrees for a srw. If you have Death Wobble with the 285's I think some guys go 5 degrees ...Cquestad....others 3 to 3.5 degrees. Alot depends on your tires and rims (as in offset). ks
Are those ball Joints actually adjustable? Or are they offset allowing for angle changes at the time of install?
All the offset joints I've installed are a 1 shot deal, and you need to get alignment angles before installing the new ones in the correct way.
i have never had the death wobble (lucky me!!) i know the ball joints need to be adjusted- my driver side tire is slightly slanted out-at the top! i am running 285's with the factory rims
so how do you know where to set the offset ball joints?? I jsut ahd a set installed, and now i am looking at haing to take the crap back apart and putting them back in. Not the kind of news I wantd to hear, but shame on me for not researching further before buying the parts..
RottnRam
03-28-2010 09:51 PM
firebill1720
20
03-05-2010 09:23 AM
1985cucv
06-07-2009 10:31 AM
Remnik
09-25-2008 07:58 AM
