Monitoring Drive Pressure
Just wondering if anyone has done and install using a boost gauge to monitor drive pressure. I'm looking to find out the proper way of doing a transition from the coiled tubing coming out of the exhaust manifold to the boost cage tubing… If I require some sort of in-line filter to prevent soot from eventually making its way to the gauge
DTR 1st Sergeant
The answer is yes, a filter is required if you are doing this long term or a permanent install. Failure to do this results in a ruined gauge before too long. Prefilter expect to take apart the tubing for cleaning on a semi-regular basis as soot will buildup inside.
Picked up the parts. Started with 2 micron filter (left), 1/8 inch NPT to 1/4 inch fitting (middle), 1/4 inch tubing to 1/8 inch nylon fitting (right). The filter is a sintered filter that can handle 900°F (but it will never see this temperature - it will be located after 3 feet of coiled stainless tubing). The filter was the most expensive part: $73 CAD.
I am quite pleased with how things are looking so far. I will upload a photo when I get it mounted. I blew through the filter and thought it might be restrictive but it feels to have about the same resistance as the 1/4 inch tubing itself - and even then, the tubing from the dual boost gauge manufacturer (Hewitt) is 1/16 (I think) - so I think it'll be ok!
For coiled tubing I purchased 10 ft of straight stainless tubing from Swagelok, then wrapped it around a 2" pipe to create the coil. Stiff stuff the stainless is - took a bit of muscle, but it was easy nonetheless.
Phil n Az
10-27-2008 06:19 PM
jtrimmell
10-10-2008 11:37 AM
Dodgezilla
03-22-2008 04:49 PM
