Mini-Pack from Kore/Lorenz/Carli or this one?
In the quest of improving the ride quality when the box is empty I am face with this dilemma:
Should I go with one of these?
From Kore:
http://www.koreraceshop.com/kore-hp-...sel-1-1-1.aspx
From Lorenz: (see bottom of the page)
http://lorenzindustries.com/products_leafs.html
From Carli:
http://www.thecarlisuspension.com/do.../addapack.html
Or this one?
Website:
https://sulastic.com/default.aspx
Please give me your inpute, thank you.
From Kore:
From Carli:
Or this one?
Website:
Honestly, if you can pony up the extra cash, get full replacement leaves...
I went with Carli mini-packs, and while it did improve the ride(mainly over sharp bumps) I wish I would have saved up the extra dough towards the full leaves.
IMO it didnt improve the ride well enough to justify spending it(instead of saving it towards the full replacements)
I have the KORE HD leveling kit and KORE mini pacs, and I have been real happy with mine. I could tell a big difference, especially when I finally put on some Toyo's. I agree, the full replacements have to be better, but they are pretty pricy when the mini pacs do improve the stock ride in many aspects. I also run traction bars and Im sure that would take some of the benefit out of the full replacements in my case being that the bars do actually stiffen the ride alone.
I say save your money and get you some mini pac's, Lazar Smith traction bars and the SSSSS he has, and your truck will corner like a dream. XXLTEXAN and I both have this setup, and you'd be suprised at how well you can get a Dodge with 35x12.50's to round a corner,........cause you know I dont wanna lean like no caddy-lac!
Thank you Gents!
You guys talked me out of expending $400.00 as it sounds that the Mini-packs do not make that much of a difference on the ride quality.
The full pack set is around $1500.00 and for that I need to put it through my Secretary of Economy for approval.
Thanks again.
Thanks again.
Thank you Gents!
Thanks again.
Thanks again.
Thank you Gents!
Thanks again.
Thanks again.
Is it worth getting Dons leafs, then saving the insane amount for Carlis bags? Or should I just go with Carlis full leafs Pauli? All im missing from my suspension is arms, and leafs. Got the KINGS at all 4 corners, the stablizer, and the new 08.5 steering. I just cant get over how much the airbags are
Thurens leaf's are insane, Its the best money I spent. Theyre 4" longer than stock, recenter the wheels to clear 37's, and use his proprietary shackles. INSANE, i tell you. Use timbrens until you can afford the airbags. Pauly did!!!
Heimz.
Heimz.
Ya, thats what I thought. But I have a shell for my truck that I usually keep on during the winter, so when I was talking to Don, he thought Carlis would do the job. I personally want to be 100% Thuren, as far as suspension goes. We will see.
Depends on how much you wanna spend on your truck really. The minipacks helped mine a lot, plus I haven't noticed a loss in capacity.
I should have picked up full leafs back then because I believe they were only $800! The minipacks I calculated were somewhere around $380.
Inflation I guess... But the truck does fine with them, I'm very happy with them.
