Minds almost made up(PROGRAMER)
Smarty
What is being overlooked is that most of these programmers "fool" the ECU into thinking that it needs to add more timing/fuel etc.... whereas the Smarty actually replaces the stock program to a well matched, variable power setting.
My brother (HOHN) has been helping the development of the smarty, and let me tell you, from what he has told me in comparison, unless you have full programming ability like the mustang and camaro guys where you can manipulate the ENTIRE program yourself, I think that smarty is the best way to go for that reason...
No I never did, I just ended up running the diablo with my hot juice, I think that I am going to add in an mp-8 next spring. Got a bit of head work etc in the mean time to keep me busy (and broke)
Kevin
Kevin
I havent run hot juice by itself to be honest. I just kinda plugged it in and left the pred at the setting it was. The snow came so I havent fooled with it much since then, but it sure worked good without even fooling with it
Kevin
Kevin
