Min-Max Gauges
Old 06-23-2004 | 11:24 AM
wengerda's Avatar
Min-Max Range for Gauges
I had installed Pyro, Boost and trans temp gauges in my new truck. Now my question is, What is the normal ranges for this three gauges. Normal driving versus towing trailer (9,000lbs). I know that is not a standard range, but what is at least normal before I have to worry about it. Thank you all.
Old 06-23-2004 | 09:16 PM
Ray Roton's Avatar
Very hard to answer.
Pyro...Depends on how it is installed (in the manifold, or in the down pipe)
Tranny Temp...Depends on how it is installed.
Boost...Depends on how heavy your foot is. With a stock 04 engine, you will prob ally not see over 22 or 23. An 04.5 I think will be a little higher.
Old 06-23-2004 | 09:26 PM
phox_mulder's Avatar
Pyro, most likely normal would be 600-900 cruising empty.
Don't want it over 1300 if pre turbo, 800 if post turbo, for any extended length of time.
I've seen 1250 running empty, flooring it.
Tranny temp, 270ish is when the warning light on the dash comes on,
at that point it's pull over and call a towtruck, tranny is toasted.
Mine, in the hot line to the cooler, runs 160ish cruising, have seen up to 190 stuck in stop-go traffic, 230 hillclimbing offroad.
Boost, 10 cruising, 19-21 WOT, as that is where it is most likely wastegated.
Being that mine is a 2nd gen 2002, number might vary slightly.
phox
Old 06-24-2004 | 10:26 AM
nickleinonen's Avatar
max boost on my 04 is 25psi. the wg cracks at 23 psi and will creap to 25psi under hard acclaration. for pyro, mounted pre-turbo, i can see 1250°f under wot acclaration at high rpm's. for shutdown, i wait till i am a little under 300°f. as for trans, i don't know. i have a 6 speed...
C Schomer
07-16-2012 09:18 PM
Kman9090
29
12-06-2007 07:43 PM
coontz0473
17
09-22-2006 04:52 PM
Duckman1993
09-12-2006 08:50 PM
Arkansas
02-19-2003 12:52 PM
