Mcleod clutch installed but..
put the clutch in and now it wont go into gear when ideling and if i start it in gear it creeps like the pedal isnt all the way down..any ideas
i had the same thing,had to install adjustable clutch slave from southbend and now is fine,seems like stock slave not strong enough to hold the extra pressure from pressure plate so clutch not releasing all the way
did you get the street twin?? or other???
most ALL the clutch manufactures I have seen require a hydro upgrade on the G-unit trucks....if you have not I would try the upgrade...if that dont work you probably damaged it on install=bent a the disk or a finger.
let us know what you find.
Rick D
08-08-2005 08:49 PM
Got Smoke?
10-26-2003 12:03 PM
