MBRP Dual Exhaust?
Old 09-16-2007, 06:07 PM
Nate-03 D's Avatar
MBRP Dual Exhaust?
I just went to the DTR store to look for a dual exaust from MBRP. I know they make a dual in stainless steel. But I swear they also had the cool duals in aluminized? Did they stop making them in aluminium?
Old 09-16-2007, 06:45 PM
wreedCTD's Avatar
http://www.mbrp.com/products.php?typ...&Submit=Submit
dodgediesel's Avatar
"DO NOT", I repeat "DO NOT" waste your money on the SS 409 system!!!!! It will surface rust, you will be mad and MBRP will do nothing for you...
Old 09-16-2007, 06:52 PM
Nate-03 D's Avatar
Thanks wreed!
Yea I wasen't even going to consider the SS kit, living up here it would only look good for maybe 2 years. After seeing my fathers SS Magnaflow system I decided I would settle with the aluminum sytem. I would be painting it with a rust proof Black paint maybe followed by a can of clear coat just for the heck of it. You can still use a SS tip for the aluminum kit correct? I do not want to leave it un tipped.
*Edit*. Why isn't the aluminum kit for sale on DTR anymore?
Old 09-16-2007, 06:58 PM
wreedCTD's Avatar
Yes get the nice SS 300 series tips.
Old 09-16-2007, 07:23 PM
Nate-03 D's Avatar
Anyone here running the cool duals on a 03, is there any bad dronning at cruising speeds?
I've been debating which exhaust system I should go with. A single is cool at all but everyone has that, stacks are great but I sortive don't want to loose the bed space/have to deal with water getting in the pipes then soot going all over my White truck when I fire it up. I've only seen 1 set of duals on a diesel in my area(it was a DMax), plus I think it would be neat to roll smoke out of both sides of the truck instead of one.
Old 09-16-2007, 09:18 PM
Little03's Avatar
I run the cool duals on my 03 and i dont have any bad dronning when cruising.
Nick.
Old 09-16-2007, 09:30 PM
Nate-03 D's Avatar
Nick.
Is it straight piped? Catless? Did you notice a difference in EGT's after installing the duals? Would you happen to have any pics of the rear end of your truck?
Old 09-16-2007, 09:38 PM
Little03's Avatar
Its 4 inch turbo back no cat with the mbrp muffler heres a shot of the back I cut the piping to tuck the tips up under the truck so they didnt hang down and get taken out.
[IMG][/IMG]
Old 09-16-2007, 09:42 PM
Nate-03 D's Avatar
Thanks for posting the picture Little. I appreciate it.
How was the install? Did the hangers match up well? Any thing go wrong.
Old 09-16-2007, 09:51 PM
Little03's Avatar
Not it when awsome smooth just the diver side pipe took a little messing around to get them both a square as possable and the drivers pipe was hitting my superlift bumb stop bracket but ant nothing a grinder cant fix.
Nick.
Old 09-16-2007, 09:57 PM
Nate-03 D's Avatar
It sounds easy enough. When funds get a little looser i'll be ordering this system.
You went w/ the aluminized system? how is that holding up for you in Canada?
Old 09-16-2007, 10:11 PM
Little03's Avatar
Nope I got the stainless system its all they had and its fine. winter will tell theo with the road salts but no one looks under the truck all that matters is the tips.
nick.
Old 09-16-2007, 10:15 PM
Luvnacumns's Avatar
I liked my dual system it wasn't mbrp but there are pics in my gallery
Old 09-16-2007, 10:59 PM
mudslinger's Avatar
I have had the cool duals on my '03 for almost 4 years now. I haven't really had drone problems and the aluminized has held up fine so far through canuck winters. I love them and wouldn't go without.
Quick Reply: MBRP Dual Exhaust?
