Max spool cam?
Old 07-22-2008, 05:47 PM
  #31
Got Juice?'s Avatar
I thought TTY meant a torque sequence like above in the bold.....
YES.
TTY is expressed as an initial torque rating, then a rotation specified in degrees.
Old 07-22-2008, 06:02 PM
  #32
homewrecker's Avatar
Originally Posted by StealthDiesel
Hmmm, you are right.. It does say 2 different things about the Cam retaining bolt on the F1 website.
http://www.f1diesel.com/helixspecs.html
Both values likely end up similar when done but that info is confusing.
...Joe
Don posted something on this the other day on here.He said that they end up being about the same but better to do the 20ft-lbs + 180*.
Old 07-22-2008, 09:07 PM
  #33
Coal Train's Avatar
Originally Posted by Sloverado
I have thought about the H3 as well and it seems in these CR motors the H2 is all that is needed.
Should have the sticks back today from what I here so I will be up and goin again. If I don't like the way it spools after the pull tomorrow and Saturday I will be adding a cam.
I wish Don would chime in on why he doesn't recommend a helix 3 in CR's? I really wanted one but ended up with a helix 2.
Old 07-22-2008, 09:23 PM
  #34
DTR Advertiser
Don M's Avatar
Yeah, torque the bolt ot 20 ft lbs and then turn the bolt an additional 180 degrees or 1/2 turn.
Coal Train,
The H3 is not very good in a 3rd gen unless: The twins spool lighting fast or you have something similar to a stock single. The H2 dominates the H3 in nearly the entire RPM range.
We are redesigning the H3 grind to try and gain some low and mid range back.
Old 07-22-2008, 10:19 PM
  #35
Coal Train's Avatar
Thanks a lot Don!!!
etn550
04-01-2010 12:12 PM
AH64ID
01-18-2009 04:59 PM
jmccart
04-05-2008 09:32 AM
getblown5.9
07-09-2007 10:56 AM
Zino
08-15-2003 10:14 PM
Quick Reply: Max spool cam?
