Max Fuel Pressure
Max Fuel Pressure
Hello All,
I just wanted to see what you guys have seen for the max fuel pressures on your guages, so I know if I should get a 30psi, 75 psi or 150psi sending unit for mine.
Thanks,
Bryce
Thanks,
Bryce
I have an 03 with an electric Autometer gauge installed and I am seeing max of about 9 psi. If I go with the AirDog or FASS system I will probably set it to 10-12 psi.
I had the new Autometer electric fuel pressure gauge(0-30psi) and FASS system installed couple of months ago. Idle fuel pressure is 18psi, normal driving 15-17psi and WOT drops to 12-13psi and climbs back up.
Hijacking my own thread
Well it sounds like the 0-30 PSI guage will work fine. On another note. Dogger I saw that your signature has the TAG III. I was curious if it was worth looking into and what the benefits are for it.
Thanks,
Bryce
Thanks,
Bryce
I ran 7psi stock. I bought a 15psi gauge. I put the FASS in, now my gauge is pegged. ooops -- should have bought a 30!!!
By the way -- stay away from Stewart-Warner Maximum Performance Gauges. I'm not going to elaborate on that, but if you do a search on my name, you should be able to find me belly-aching about a half dozen problems I had with them. BAD design.
Dually Driver
13
11-13-2007 09:10 PM
belfert
09-09-2004 03:23 PM
Gear Poet
06-03-2004 01:19 PM
fishin fever
02-22-2004 08:32 PM
Zino
08-15-2003 10:14 PM
