Map sensor question when stacking Juice/XZT
Old 01-15-2008 | 08:01 PM
06CTDforAU's Avatar
I'm about to hook up a Juice/Attitude in my truck to try it out and I want to stack it with my X2 XZT? What is the proper way to hook them up to the map sensor?
Harness ---> XZT ---> Juice OR Harness --> Juice --> XZT
I just uploaded the stacking file with no boost fooling into my X2 so that the boost fooling won't trick the Attitude monitor.
Another question that maybe Quad will chime in and answer. On the download page from Quadzilla, if I click on the "325 XZT STOCKBOOST" download button, the feature code enabled is stacking with no boost fooling. If I click on the "325 XZT STACK NO BOOST" download button, the feature code enabled is XZT with stock boost. Are these just backwards? I'm guessing they are but I would like Quad to verify. This is for the 04.5+ X2 XZT.
Old 01-15-2008 | 11:15 PM
06CTDforAU's Avatar
Just bumping this before I go to bed for the night. I'm planning on installing them tomorrow afternoon. Thanks in advance!!
Also...... this may sound dumb, but when someone says "x" goes first and "y" goes second, does that mean "x" goes on the engine side or the harness side?
Old 01-16-2008 | 08:13 AM
omaharam's Avatar
Before it was internet updateable, when the xzt was a stacking program, it was simply a pressure box. In that case, it won't matter in which order you plug them in. I had mine pugged in both ways when I had mine. If that program only gets rid of boost fooling I'm not sure it's going to work with the Juice.
Old 01-16-2008 | 10:39 AM
06CTDforAU's Avatar
Thanks. The program from Quadzilla is a stacking program with no boost fooling. The other stacking program that has boost fooling enabled says "pressure only" in the description so I assume that it is the same for the one I downloaded with the exception that mine has no boost fooling.
Old 01-28-2008 | 12:25 AM
Wild04.5's Avatar
i run my Juice stacked with my XZT x2 and my Quad Rail Pressure gauge all stacked.. doesnt seem to matter which way the harness is..
im running the internet file from Quad's site with no boost fooling.
very smooth power curve from bottom to top. i tend to run the Edge in 3.
some increased smoke..
nascar-co
04-12-2009 01:42 PM
GCF724
03-02-2007 12:18 PM
CTD01
01-03-2007 11:17 AM
haloman
12-30-2006 12:53 AM
Dodgezilla
03-05-2006 09:16 AM
