View Poll Results: Mag-HYTEC diff cover, worth it or NO?
Yes its definetly worth the $250 for how you use the truck
17
51.52%
NO, its a waste of money and not worth the $250, you dont need it
16
48.48%
Voters: 33. You may not vote on this poll
Since my 05 rear diff cover is already starting to have a little rust spots, im thinking of making it look better. So other than the fact of easier diff oil changes and cooler diff oil, is the MAG-HYTEC worth the $250 a diff cover? My truck is pretty much a daily driver back and forth to work, local towing( under 5k lbs) within 500 miles about 2-3 times a year, some occasional street and highway racing and thats about it. Well I definetly dont think of getting the front, but only the rear. Is it even worth it for how I use my truck? Yea, I will be getting a TST chip and a bigger turbo down the road(thats about it). If not, what can I do to my old one's or a cheaper alternative so I can get rid of the rust?
Originally Posted by ptgarcia
For what you do its a waste of cash. Just paint the stock cover.
They're definately more appropriate for harder worked trucks. One will look good on your truck and probably lower diff temps a bit, but I doubt your temps ever get high enough to warrant the expense. I'd spend my monet elsewhere.
There definately more appropriate for harder worked trucks. One will look good on your truck and probably lower diff temps a bit, but I doubt your temps ever get high enough to warrant the expense. I'd spend my monet elsewhere.
If you like the looks of the Hytec, take a look at PML covers. They're good looking, and with exception of the dipstick, do everything the Hytec does for less. And yes, I know the Hytec has slightly more fluid capacity. Not worth the difference in cost to me. I'll eventually get the PML covers. I like 'em.
Well I guess im the lone dissenter so far. I love it. I think it was well worth the money, but mainly for the looks. It's not going to make your truck any faster and the cooling is probably not that big of a deal unless you pull heavy all the time. It will make gear oil changes a little easier. But, dang, the main thing is I think they look sooooo nice. My 2 cents.
DPP has them for slightly cheaper. www.dieselperformanceparts.com
Originally Posted by carcrz
I voted yes, but I would buy the PML one for $100 less.
Originally Posted by MikeyB
AAM Applications (click for more information):
AAM 9.25" Ring Gear, 14 Bolt, Front for Dodge, P/N 10740
AAM 10.5" Ring Gear, 14 Bolt, P/N 10302
AAM 11.5" Ring Gear, 14 Bolt for Dodge and GM, P/N 10361
AAM 11.5" Ring Gear, 14 Bolt for GM, P/N 9511
Not sure which one it is?
http://www.yourcovers.com/newdifferential.htm
You only pretty much do the rear, right? Absolutly no need to the change the front?
