Lug nuts for H2 wheels
I used my stock lug nuts. Some guys were running 2 sets of stock doubled up so they didn't have to modify the stock center caps. I just modified my stock center caps.
It appears that the stock lug nut for a steel wheel will not work due to the taper in the lug nut. The H2's have a flat collar and the opening seems to be larger. Are the lug nut different between steel wheels and alumnium.
That's not true. I use the factory lugs for my chrome clad steel wheels to keep my H2's from flying off.
I just put mine on a couple of days ago. I used stock lug nuts and a second set to get the caps on. When you double up the lugs you have to use some lock tight to keep them on. But just buy the weak blue stuff-medium strength. That way they will come off easy with a lug wrench. But they will not back off easy.
Yes mine do also. BUT when I found out how much a cap could cost at the dealer. I felt a $10 tube of lock tight would be a good insurance policy. PLus that second set is only holding by a few threads
Trebor
09-14-2006 04:52 PM
guzzirider
11-28-2005 07:48 PM
Dr.Kayak
01-25-2005 02:58 PM
