lsd or locker for aam
I started with a search on this, but there are numerous threads and way too many posts to read.
So, is anyone making an LSD or any type of locker for the AAM diffs yet?
I think AAM is the only one making traction devices for them. I hope someone will eventually come up with something aftermarket, because if this anti-spin breaks, it can't be cheap to replace. $285 for a factory option, but probably more like 4-500 from ******* to replace.
depends on the lockar type. I think the power wagon has an e-locker. as long as you can open you front diff up it is great. optimumly you would have a selectable locker front and rear.
normal locker front and rear can cause you trouble in the wrong circumstances. hard to steer/control in tight places.
An auto locker in the rear of these trucks wont hardly ever be felt. A lightweight jeep cherokee wasnt that bad. I was hoping to find that eaton was gonna work their new e locker for the 14 bolt. You will notice in ice or snow but it is something else that is learnable. The front of the power wagon locker sounds good.
Yukon Gear just came out with a lsd just like the detroit TrueTrac
$480 something
www.ring-pinion.com
www.schaefersringandpinion.com
I think it is called the powerlock
$480 something
www.ring-pinion.com
The lsd @ randys is the factory torson type made by aam. trachtech has a detroit in the works as well as a truetrac, arb shuld have a unit available soon aswell
in the front you can run an eaton e- locker
pm me for more details on any of this...
Gypsyman
01-04-2004 01:10 AM
