low rail pressure problem
Old 12-07-2009 | 08:47 PM
agregersen's Avatar
so just recently my rp gauge is reading about 4200 at an idle and only 6000 cruising at 65 mph if i floor it it will jump to 20,000+. my rail is capped and the truck runs good.i am getting a little bit of a fuel knock while cruising too.i unplugged all the connections and cleaned and dielectric greased them with no change,also there are no dtc's.any ideas why its so low while cruising.thanks
Old 12-08-2009 | 08:52 AM
Floor It's Avatar
I would check your PRV (Pressure Relief Valve) first to see if its leaking.
John
Old 12-08-2009 | 01:54 PM
Fisherguy's Avatar
His rail is capped so it can't be the PRV.
CP3 acting up maybe?
Old 12-08-2009 | 02:53 PM
Floor It's Avatar
FCA not working right,maybe sticking, small cross over tube leak or the injectors flowing a bit too much back.
John
Old 12-08-2009 | 03:24 PM
rich's Avatar
i'd say the injectors are starting to let some flow back. does it seem to take a little longer to start
Old 12-08-2009 | 06:36 PM
agregersen's Avatar
no it seems to start normally. what are some symptoms of a fca going bad. could it be the rail sensor? if so how would you check it.thanks
kingey
02-26-2020 08:39 PM
5.9Excursion
03-13-2008 10:56 AM
danshsss
07-06-2007 02:47 AM
judge88
Competition / Pulls / OffRoad
02-04-2006 08:35 PM
big red psd cc
12-19-2005 11:26 PM
Quick Reply: low rail pressure problem
