LouD Truck Horn
search for airr horn. There should be several threads.im still figuing the best route for me too. the other day i sure felt mad when i had to use my horn (its not often) and got this pathetic squeak.
1 Post
I have heard and seen Mike's solution. It scared the daylights out of those ricers and a couple of Hooters girls! And upon inspection, I thought at first it was a weapons pod of some sort. Anyway, I have to do something about that little wimpy stock horn too. It belongs in a Hyundai, not a diesel truck. Anybody come up with a solution that does not involve a locomotive or ship?
I put grover air horns in mine and love them.. Reasonable priced and easy to install... Kit came with everything I needed to install them.. I'll post a picture..
Here is the link... I got the 1605 kit
http://www.groverairhorns.com/truck/truck.html
Gerry
Gerry
I went the cheap route. Just go to ebay and buy a cheap set of horns. Yea they are a little cheasy looking and they are plastic but they are loud. The ones I got just run a very small compressor (just enough for the horns) and connect with a short length of tubing to the horns. Mine are run by the normal horn switch just tapped into the horn wire and ran it to my relay that came with the kit and hooked it up to the battery. Now when I hit the horn they all come on... It isn't a train horn but with all of them blasting it is definately loud and cost me about $20.00
Air Horn Big Blast
Originally Posted by wtf700
Want to put some kind of a Big truck air horn on my 2500, what do you guys have, what works good and LOUD. Thanks
I have 2 BIG brass air horns off of a 1950's vintage portal crane that we scrapped at work. The pipe inlet is 3/4" NPT. I hooked them up to my air compressor in the garage and every new years eve, I win the neighborhood noise contest. Was thinking about putting them in the truck. I have the pacbrake compressor, need a big reservoir.
i have something similar to the grover 1275's on my truck with compressor.
i also have a set of grover 1601's i belive for sale at a great price, pm me for details.
heres the biggest collection of info on horns including sound clips on darn near each and every one, search around and look, you can find it if you try. http://atsf.railfan.net/airhorns/index.html
