Lots of new Toys But truck is acting weird?
ok guys i just installed new turbo,head studs, stg3 cp3, injectors, exhaust manifold,mp8, bully tog tripple dog, and a fass system. my check engine light is not on but when i check codes anyways it says pc121 ? and my speedo dosnt work the abs and brake lights are perminetly on my 4 wheel drive wont engage and my tow mode and overdrive button dont work and i cant see my P R N D 1 2 gears on the dash there not lit up? dos anyone have any ideas on what could cause this?? please help me.
yes i took it off and nothing different happends i tbelive i had that problem before i put the bullydog on but i cant remeber beacuse i only started it 4 like 2 mins then added the bullydog
For the PRNDL on the dash, that goes off if you dissable torque management I believe(It tells you on the prompt as youre loading the bully dog)
As for the rest, havent heard of those specific problems, but id give bully dog a call for sure...
tow haul and overdrive maybe you tapped the wrong wire when you did your lockup switch. Did you get your trans upgraded yet??speedo,abs,emergency brake light sounds electrical check fuses and relays
