lost power
If standard smarty gave you 30hp less than the VA 5 then it looks like beta Smarty would be a good program to try. Were you running much meth or just water. Water isn't a drug....just ask the DEA. ks
So you got the standard program as in stock, just with the wild tq management? BTW- you went with a twin set up very similar to mine, just a little smaller.
Also Justin, let me know the next time you plan to go to the track.
yep, standard program wild tm. i was gonna go bigger on the top charger but this setup is cooling what im doing now. at least on the dyno. still cant turn the tst up hardly at all though just looses power but holds rail pressure. im thinking i need bigger injectors and less duration. or a freakin motor that can take a good program. not a whole lot out there for an 03.
11.30's on fuel??? Is that right huh?? What have you done different??? When I was there last time you sprayed it to 11.50's but had issues on the big end.
BTW guys- I probably won't be racing, I just wanted to be a spectator and listen to the people flipping out when Justin rolls thru the traps. LOL As for the TST, there is a reason you are having issues with it....
lloyd, i went 11.49 on fuel 2 weeks ago with the old twins on some setting i thought was my best. after some dyno time i found another 38 hp playing with some things. so 11.30 or better is doable. please enlighten me my issues with the tst before i throw it out the window
