View Poll Results: delete stock fuel filter/add 2micron gdp
keep stock fuel filter add 2 micron gdp to frame rail
85.71%
14.29%
Voters: 7. You may not vote on this poll
looking for some advice air horn, fuel filter location
Kind of long so bear with me....
I want to buy an air intake horn question is.... In the future would like to consider deleting the stock fuel filter canister and install a bypass GDP 2 micron setup. I would obviousely upgrade the lift pump and use the "big line" kit as well. If this is a good setup the reason I ask I can dump my stock intake air horn and then buy the power-flo intake and then mount the fuel filter onto the Backside of the power-flo( it has built in mounting points). The reason for mounting tp the backside of the power-flo is I have no room in front of the air -horn due to my oilguard by pass being mounted in the front. See where I am going with this?. Function and ease of maintenance is my biggest concern. If the idea of not being able to delete the stock canister is not good due to functionality etc. I will update the air horn to another brand and just get a remote mount fuel filter for the frame rail.
Because of my budget I am trying to map out upgrades that will work with future mods. to have a better more professional fit.
Sorry for the long question
DNRCustoms
02-03-2009 08:14 PM
natlchamp2k4
03-13-2007 05:47 AM
royta
09-17-2005 10:25 PM
