Looking for pics of stainless rocker panel molding on silver truck
Old 04-10-2009, 07:56 PM
CTD2001's Avatar
I am thinking about buying some rocker panel moldings to help protect the rocker panels on my truck. Just curious if anyone has the stainless panels on a silver truck so i can get an idea of what they would look like, thanks.
Old 04-10-2009, 09:15 PM
pind's Avatar
I have a truck in the yard here with that setup, and it looks good.
On a darker truck, they look gaudy as heck, but on a silver one, they blend nicely.
Old 04-11-2009, 07:50 AM
CTD2001's Avatar
Thanks for the advice, any chance you might be able to snap a picture of it? Thanks
Old 04-12-2009, 02:00 AM
Jon_M's Avatar
[/IMG]
Old 04-12-2009, 02:02 AM
Jon_M's Avatar
Bear with me because this is first photo I have posted in a forum an was not real sure how to do it.. If you would like more photos send me a pm and I will try and get you some more if this helps you out...
Old 04-12-2009, 10:22 AM
CTD2001's Avatar
Thanks very much for the photo, just what i was looking for. I like the way it looks, very suttle and not a very big contrast and not to gaudy looking. Thanks again.
Old 04-12-2009, 01:37 PM
Jon_M's Avatar
Your welcome. Glad I could help. I didn't go with the full width rocker panel because I wanted to keep the black trim on the bottom of doors to break up the silver on the truck. It looks great all cleaned up as well.
Old 04-12-2009, 01:47 PM
CTD2001's Avatar
Is that the 6" version or the 8" version. Looks like it is 6" but just wanted to check, thanks
One more question, is the entire back side of the panels sticky 3m tape or does it just have a couple of strips on 3m tape on the top and bottom? Does alot of crap, like dirt, salt ect get stuck in behind them or is it a pretty tight seal between them and the actual rocker panel? Thanks
Old 04-12-2009, 08:40 PM
ModManiac's Avatar
Ive been thinking of taking mine off, Im almost on the virge of thinking its gaudy, but it was on the truck when I bought it and I am a little scared of what the paint will look like underneath.
Old 04-12-2009, 09:15 PM
CD in NM's Avatar
I've been thinking about putting a set of the stainless rocker cover on too.
My truck is a two tone - Atlantic Blue over the Silver at the bottom. I figured on getting the 8-1/2" tall ones made by Wilmore. They'd cover more of the silver and probably blend in real well with a little of the silver paint showing anyway.
As far as the Wilmore ones I have seen, they are covered/backed entirely with the the 3M adhesive tape.
CD
Old 04-12-2009, 09:59 PM
Jon_M's Avatar
They are covered completely with 3M tape. I have not had any problems with anything getting down behind them. As long as you get it stuck to truck good nothing can get behind. I believe mine is the 6" version but would have to measure it to make certain.
Old 04-12-2009, 10:06 PM
augustfirst's Avatar
Ask and you shall receive.
Old 04-12-2009, 10:31 PM
CD in NM's Avatar
augustfirst.
Now that looks very fine. Looks like the 8-1/2 wide, catches that top line and gives a nice dimension. Excellent.
Did you heat them up before you installed them? Some people apply them heated up first. Others heat them some with a hair dryer rather than a heat gun after putting them on. Some just put them on. What did you use to prep the surface? I was thinking about denatured alcohol, it should clean off any wax, etc. I believe 3M makes something for surface cleaning also, saw it but can't remember what it contained.
and by the way, excellent first post, welcome!!!
CD
Old 04-12-2009, 11:04 PM
Thanks... and thanks!
Wish I could be more helpful but I bought the truck this year, its an 05, and they were already installed...
Old 04-13-2009, 12:05 PM
pind's Avatar
3M makes a wax and adhesive remover, comes in a black can, dump some on a rag, and wipe the offending surface. Pretty potent stuff, and not overly expensive. I use it on bare metal when building projects that have to be painted, takes the oils and cutting residue off with no problems.
Quick Reply: Looking for pics of stainless rocker panel molding on silver truck
