lookin' for injectors!!
i only have the edje juice and an intake but plan on dooin alot not gonna put them in right away but there the same price as the lowere hp ones so im not gonna buy twice but im just doin some reserch and lookin at stuff for now.
If you plan on making 700 hp and not towing anything then go for it. You will require a modded CP3 at least and a dual CP3 set up preferrably. For a turbo you will need at least a sps66 or prostreet 66 if not more....preferrably a medium set of twins. They make Flux 1,1.5, 2, 3, 3.5. for a reason. Flux 4's are pretty much for competition use.
What tranny do you have as you will need a fully built auto or a DD clutch before you get started.
Here is your list.
Real Gauges
High Flow Lift Pump and 2 micron filtration
5" exhaust
AFE Stage II or equivalent
Tranny upgrades
A good Downloader
The Hot Juice with Attitude but preferrably the TST R49++
head studs
Big honking turbo
Modified CP3 or Dual setup
Then a set of big injectors.
IF you decided on a more practical set of say Flux 2's then you could insert those in the list before the downloader.
Good Luck, Keep us in the loop, ks
Here is your list.
Real Gauges
5" exhaust
Tranny upgrades
A good Downloader
head studs
Big honking turbo
04smoker
03-22-2009 07:54 AM
Jason A
14
06-18-2008 10:55 PM
mr T
08-05-2005 05:50 PM
