Lockup Switch on an '03 with 48RE
Old 10-18-2008 | 02:18 PM
2whistlers's Avatar
How to? I didn't see a write up on one unless its the same as the '04.5+. Any info is great!!!!
Old 10-18-2008 | 03:12 PM
2whistlers's Avatar
Nobody????
Old 10-18-2008 | 03:42 PM
2007 5.9's Avatar
Should be the same as 04.5...I would suggest doing the 33-ohm resistor instead of the relay trick..seems to work more reliably.
Old 10-19-2008 | 05:50 PM
2whistlers's Avatar
Nobody else?
Old 10-22-2008 | 11:41 AM
2whistlers's Avatar
I know better than to think NOBODY has done this or at least knows the answer and can point me in the right direction.
Old 10-22-2008 | 11:56 AM
2007 5.9's Avatar
How many answers do you need??? The directions for the 04.5 and up is the same as the 03's.
Old 10-22-2008 | 03:45 PM
2whistlers's Avatar
Thank you. Your first response said "should" be the same. Your second response said "is" the same. Big difference.
Old 10-22-2008 | 05:09 PM
soulezoo's Avatar
DTR 1st Sergeant
Not the same...
you do not need the resistor. The instructions for the 03 are in the same thread if you look long enough.
Basically, the wire to the tranny and the wire to the fuse box coming to the switch. No resistor needed.
cowboykilla235
02-17-2013 04:02 PM
JQmile
09-15-2010 11:43 PM
dirtracer1880
12-11-2008 12:13 PM
Cowboy_Customs
05-06-2008 10:39 AM
pybyr
08-15-2006 03:25 PM
