lockers / limited slips
I can't face another Colo winter without a decent rearend.
any one have experience on aftermarket units, to include ARD
Anyone has history with an installer around Colo Springs CO
thanks guys
thanks guys
I live in denver and have been considering a switch to dodge from GM as my personal vehicle. The locker in the GM's works pretty well in the snow here, I gather from your post that the stock limited slip in the dodge doesnt?
Bill
Bill
the limited slip in these trucks are junk, i got stuck in about 3" of sand one day and only had 1 wheel spinning. I was about 10 seconds from pulling off my diff cover and weilding the spider gears together. I dont think there is a locker made for these rear ends yet. Since Dodge went to the american axle and away from the Dana 60/70. I could be wrong, i havnt done any research in about 6 months since I am deployed right now.
Hey Bill, I seem to remember you from the Chevy forum. Still waiting on a DMax Suburban? Anyway, the AAM axle Dodge is using is the same one behind the GM DMax. I'm fairly certain the "GuvLok" differential is only available for the 7.5 inch to the 10.5 inch AAM axle. Nothing is available for the 11.5 inch gear that is used behind the diesels except AAM's own "TracRite" gear type differential. In the Dodge application it doesn't live up to it's potential because of the lack of traction control. This robust unit would probably be great with that addition. Gear type differntials require traction at both tires to make both wheels spin. If one tires loses all traction it is no better than an open differntial with the tire without traction getting all the power. Sure the Dodge owners manual says that modulating the brakes can sometimes get the wheel with traction spinning but how is that any differnent than an open differnetial? It's not. I've been stuck several times in my truck. I never did in my Govlok equipped GM gasser.
I have read that some guys have had sucess by gently applying the brakes until the power starts to tranfer to the other wheel. Don't have one, just read about this.
The TracRite is identical to Detroits Truetrac limited slip (the best out there) with the exception of the amount of torque bias (3:1 for the Truetrac, 2:1 for the TracRite). That less aggressive torque bias is it's only weakness. It works well for me, however. And yes, applying a little break will help.
An Eaton E-locker can be added to the front diff. Give Differential Systems in San Diego a call (619-298-3568) if you have questions.
Other than lack of parts availability, I prefer the AAM axle in the rear.
I own a drivetrain shop and I have worked on too many Dana axles with the same stupid problems.
Have yet to see an 11.5"AAM in the shop. Pretty good considering what kind of power guys are putting to them.
There are 2 different posi options for these axles from the aftermarket, a helical gear type(like factory)and the GovBomb style.
I like the factory posi, but I don't rock crawl with my truck. I install dozens of TrueTracs every year. My posi of choice.
Applying the brake does the job when required.
Originally Posted by welndmn
I wish ARB would make a locker
Yeah, I'm dissapointed!
Tony
Originally Posted by griggs43
do yall no if they make one for the front for the 9.25
As for the rear. I dont know what everyone is complaining about. Mine locks up fine in mud, sand, ice, pull track... never had a problem. Of course we talked at length about this same subject a few months back - some people had different theories about why some locked tight and some seem to just spin one wheel. I still dont know why some work beter than others. Well, I have a theory but dont want to say might make someone mad
