A little dissapointed
Last night I installed the Ramifier. Started the truck and there is a very noticable difference in engine noise. The engine light came on and has stayed on. I drove the truck to work this morning (25 miles) and I had a hard time telling whether there was any difference in performance at all.
Anybody out there have the same experience?
Must be a problem with the unit or the install. Did you check the pins in the connectors before you put it on (the Air Force drilled that one into my head when I was in missle maintenance)? Are all the connectors correct and tight? Any loose or unconnected wires? Never hurts to have a second pair of eyes check your work.
If all is well with the install, I would call dennis at TS performance for some assistance.
When I put the RAMifier on my truck, the change was big and right now! MPG went up a small ammount when my foot is not pressing to hard
Good luck, I think when you get it sorted out you will love this mod.
I actually installed twice, the first time I installed the orange plug backwards. THe truck would not start so I looked really closely at the pictures and figured it out. The second time the truck started right up. I was very careful about checking pins due to previous posts on the subject.
You must have a problem with the box (I wonder if hooking it up backwards and applying power hurt it?) Give Dennis a call.
As for rough idleing - mine idles smoother with it installed
Increased engine noise - different but not increased
Let me know what you find out.
i agree with blown32...the engine noise isn't louder...just different...and as far as the rough idleing goes...my engine runs smoother too..
my guess is that there is a wiring harness problem...either plugged in wrong...or the in cab **** is wired backwards...that wa the case on mine...once i switched the wires back...all was good
I just installed Ramifer yesterday and felt a big difference in performance.
The engine sounds different but runs fine. Idles fine no difference there.
The only thing I really noticed was the EGTs run up much faster. I can see 1,400 to 15s on full throttle runs.
Re: A little dissapointed
Just mailed the unit back to Dennis at TS Performance, you are right , good guy to deal with. The unit doesn't sound as though it is working properly based on all the posts. Many thanks for the input.
Mike,
You'll enjoy it when you get it back. I returned an EZ in exchange for the Ramifier and like it much better than the EZ. In fact, the EZ made my engine clatter much more than the Ramifier. Also, it runs much better with the Ramifier. I'm running MT/R 305s and can seriously burn rubber (not that I can afford it) from a dead stop now.
Where are you in Houston? I'm in Seabrook. If you're ever around Kemah/Seabrook, give me a shout.
I've had every rail box mad on my truck,except the new Quad Box,and all I can say is,if you was instand throttle response,Dennis is the man,and I've been very pleased with his box!!!!
one54ton
25
04-30-2006 06:39 PM
CTD2001
02-09-2006 08:23 PM
halerazor
24
08-31-2005 11:35 PM
kingofdodge7131
05-03-2005 02:56 PM
