Lifetime Oil Filter
Lifetime Oil Filter
I have an FS-2500 bypass filter so I thought I'd get one of these goodies for better flow - especially as temps start to dip going into winter.
Had a PurePower lifetime filter before, but I found it to be cheaply made compared to this one.
What micron filtration, if its not 25 to 30 I would stick to the Donaldson, $8 bucks a piece, how easy are they to clean and how much trouble, and the one I looked up was not cheap, in 8 years I have used about $110 bucks in oil filters, just my .2c worth.
My question is why?
I wouldn't trust my motor to something that can stop filtering well because of age or an improper cleaning/reassembly.
It seems to me you are better off with a good filter and change it with the oil rather than put contaminants from your old oil into your new oil.
Just my humble opinion...
I didn't buy it to save money.
Here's my reasons, which will be different than yours. My truck is very different as is probably my climate.
1. Have you ever seen oil flow at -40°? I have. I'm a chemical technologist and have performed pour point tests. Even the lighter weights start out pretty thick at -40.
2. Flow through a throw-away filter is reduced quickly as it catches debris over it's life span, and the effect is exacerbated by cold weather.
3. I have a bypass filter that will catch everything and has a much higher capacity to hold oil contaminants than a standard filter, all without affecting flow.
4. I have three turbos on my truck - I want fast oil flow at start up in cold weather. I've seen my aftermarket oil gauge ramp up to 80 PSI trying to drive cold oil (50°F) through a new throw-away filter.
These lifetime filters are super easy to clean. You'd have to be pretty careless to damage it when cleaning. Soap and water. That's it. In fact, they say you can toss the filter in a dishwasher - so long as your wife doesn't kill you for doing it.
So those are my reasons. For me it makes sense...maybe not so much for others in different situations.
Our unique, patented Filter in a Filter technology cleans oil much more efficiently than other spin-on filters on the market today. The micronic, 3-dimensional weave in our primary and secondary filter assemblies captures particulates at 25 microns absolute with 98.56 percent efficiency, yielding a beta ratio of 75. It does not filter so finely, however, that it strips out the oil's important additives. Optimized to maintain TBN (Total Base Number) and viscosity, our filter protects engines from scarification while promoting oil flow that is 14 times greater than standard filters under the same pressure in pounts per square inch (PSI).
I have an Amsoil by-pass filter as well,but only one turbo.
JMHOP
Jim O
RDR
12-12-2007 06:43 AM
bdaniel
06-04-2006 08:26 AM
