Liberty Canister Module ?????'s
I am looking at getting the liberty canister for an aftermarket LP, but I have a question on whether there is any difference between the one that you can order at GDP ($189) or the one with part #5140832AB that you can order thru oemparts online or something like that for roughly $80. Is there something different about the GDP one that make it $100 more or are they both the same and will both work?
Anyone know? Also, it looks like the drawstraw v from Genos garage is just a tube that replaces the pump in the stock canister allowing you to keep your original canister but functioning like a liberty canister. Anyone know anything about that? Thanks
I haven't looked at the module from GDP, but Vulcan Performance has one that is already modified with a draw straw and ready to go. The one from GDP may be the same thing. I haven't looked at the Liberty canister from Vulcan for awhile, but if they use the Draw Straw I, there are several plumbing options, fuel return into canister etc. Check out www.vulcanperformance.com
https://www.dieseltruckresource.com/...d.php?t=208226
Might be some usefull info for you
Thanks for the replies everyone. I saw the ones on GDP and Vulcan. Pretty pricey it seems. That is why I am hoping the ones you can buy from a dealer or online are the same (minus the drawstraw), because they are significantly cheaper. I don't really plan on going up much more in HP, so I think the stock liberty canister and Raptor 100 will suit my needs just fine.
Sandaholic
49
09-02-2008 07:55 PM
Sixpack73
123
08-09-2008 02:32 AM
Fisherguy
26
05-22-2008 11:31 PM
ct2500
05-04-2008 04:07 PM
