leveling spacer help!
Your only bet is this thread https://www.dieseltruckresource.com/...d.php?t=134071
CTC Suspension is working on a 3.5" spindle for the 2500. I spoke with them yesterday - you can check the link above for the details.
But the 1500 spindle and the 2500 spindle are different and I suspect it is due to the hub and bearing size of the 2500.
Bad news I just got off the phone with them and they said that they didn't have anything and didn't know of a company that made it for my truck so i am a little right now. so any help from someone that knows where we can get a left for our 2500 and 3500 2wd. Thanks,
Fire Rescue,
Can you take a picture of the front suspension setup for me? I haven't looked at the 2wd setup before. With a picture I may be able to help with ideas.
tell me what all i need to snap shots of and i will do as soon as i get can. i was thinking about having some one fab something up for me but not sure how they would go about doing that. i might be able to get the pics in a few mins. thanks,
Get shots of the upper and lower control arms, coil springs and bucket, shocks and mounts, sway bar links, spindle, and a nice overall of each corner (front only).
Well, I won't be creating anything myself, but I can definately toss some ideas around and maybe help get you 2wd guys on the right foot.
Hmm, is the upper arm really at that much of an angle relative to the lower arm, or is that just an optical illusion? And I can't see a droop stop anywhere to limit droop. Is there a stop somewhere on top there?
Anyway, the best way to accomplish a lift would be with a spindle. You can do it with a spacer or new coil but 1) you'll lose down travel (droop) and 2) may run into alignment issues depending on how much adjustment there is. Actually, looking at the upper arm I don't think any of this will be a real issue.
What you need is someone willing to be a guinea pig and try some custom springs or tear apart the front end and see if a spacer will fit up there. Then try to align it. But it looks like it can be done.
So does anyone make a 6" lift for the 2wd? If they do it most like incorporates a lift spindle, and that may be something that can be bolted up without all the drop brackets to give just a 3"-4" lift. I'll do some diggin' and see if I can find anything.....
Coming soon from CST.....
It doesn't say if this is a spindle only or part of a bracket lift. But if its spindle only this is the ticket.
Most spindles are 3" or 4" lift. When these come out, bolt up a set and add better shocks all around. You could go all out and order custom coils and leaf springs and have a great riding truck.
I'll keep my eyes and ears open and post if I come across any new information.
1985cucv
11-15-2009 06:43 PM
CalypsoCowboy
10-22-2009 12:52 PM
bansh-eman
22
09-14-2009 01:50 PM
Ramasaur
05-15-2004 09:27 PM
