Leveling kit and pulling to the right???
1st. Did they drop the sway bar, just as a note it needs to be done.
2nd Your caster is off now, it's negative. The more positive it is the more it pulls to the left. So you need to make it more positive. I think your range is 4-5 off the top of my head on the caster. Tell your dealer to get it at 4.5 and see if it pulls... Or go to any alignment place, make sure you write down your baseline specs incase you have to jack with it a couple times.
3rd you probably want to address your trackbar as mentioned above.
4th you probably want to address your shocks as a note it should be done.
5th Report back and tell us what fixes your issue. I don't think you need offset ball joints.
sgtdiesel
25
06-26-2012 02:37 PM
LittleHoe
08-08-2010 12:43 AM
RiverRat2
08-27-2009 11:33 PM
mullercarl
Competition / Pulls / OffRoad
45
03-19-2007 10:10 AM
