leveling kit?
leveling kit?
I am new to all of this. What does a leveling kit mean? Is it the same thing as putting a "lift" on your truck? Is this a simple spacer that just lifts the truck? Sorry to ask these "beginner" type questions.
no problem welcome aboard......... they are for the most part just a spacer that sits atop the coil spring in the front end, propping up an otherwise sagging look front end. there are many kinds, solid steel being preferred over plastic as far as I am concerned. They also give that little boost to aid in clearing larger tires, 35's with the right offset don't rub but an extra 2" makes it look even better.
http://www.hellbentsteel.com/dodge/dodge-lift-kit.html
You can see a picture of this company's leveling kit here on the link. I have pics in my gallery after adding it...and some before too.
It just makes your truck sit up tall and proud in the front like a 4x4 should, without "lifting" your truck beyond practicality.
Hope that helps.
Hope that helps.
sgtdiesel
25
06-26-2012 02:37 PM
