Lets Talk Filtration ?
#31
I haven't, they say they are working on it last I heard... I am curious about the 2-3 mic as I have yet to see a Fleetguard have a absolute rating better than 5um. The FS19594 is a good interim replacement for the f.w sep, its 90% for both.
#32
Here's some brain twisting technical speak. http://www.cumminsfiltration.com/pdf...LT32599_10.pdf
#33
Yeah i think that was the Fleetguard they were talking about. Does that fit the AD for sure ?
#34
AH, you have an AD?
What's the best spin on's to use on them then?
I'm running the (advertised as) 3 micron and the WS that came with it.
#36
#37
For the final fuel the one you have is the best, its 5um.
For f/w sep run a FS19594, its the best and only other option for the funky thread/gasket size.
#38
Yeah i think the best way is to run the FS19594 then the FF5613 (on the AD) then the stock filter housing with the Baldwin PF7977. Then you get 5 micron all the way through with 95% and 95% for water. Of course you could step it up to 2 mic absolute with the Cat 1R-0750. Thats a lot of filters especially when running some big fueling mods though. There is nothing wrong with 5 micron absolute though, er i think, LOL !
I'm sure AD will come up with a 2 mic one of these days. It would be nice to have a WS on the AD with 95% and 95%. Which ever company comes up with that first will get some good business.
#40
One question for the AirDog guys running the stock filter cannister. How does the 1/2 line from the AD connect to the stock filter assembly ? Is it 1/2 fitting etc ? I forgot about this and have not seen any pics yet ? Thanks
#44
I need some better filtration, please help. If I use the Baldwin FS-1212 filter on my FASS should I still add something on the suction side before the pump? Also would the cat 2mic filter after the FASS help or would it be overkill. Right now Im using the FASS with their WS and 3 micron filter. Could set it up like yours but with the FASS in the middle instead of the factory canister. Any help would be appreciated.
