leds.
I would try recon truck lighting. They have A LOT of lighting products for our trucks. Also, the led interior lights are way nicer than stock. Let us know how you make out and put up some pictures when you decide to buy.
superbright is where to go. your 06 does not need the resistors. the 06 does have one problem that gave me a while to figure out. the rear bulb sockets are wired in a form like a p.c. layout. the led's i got needed the ground's on the same side of the base. it will take you about 20 minutes to cut and solder a couple of wires.
pet05
07-09-2006 09:29 PM
