LED Light Resistance Question...
I am wanting to put LED lights all over the outside of my trailer and was wondering if anyone had any idea as to how many LED lights I could wire up on a single circuit before I exceeded the amount of draw that one normal bulb has. I figured someone probably knows the specs on LEDs out there!
Mr. Wiggs,
I got this info:"On average, an LED marker lamp requires 0.05 amps at 14 volts, whereas a typical incandescent light requires 0.4 amps. An average LED stop lamp requires 0.5 amps at 12.8 volts, and a typical incandescent stop lamp requires 2.1 amps."
From this website, there are some manufacture links near the bottom. The links or to trucking sites which should have way heavier duty parts!
http://www.etrucker.com/apps/news/article.asp?id=45719
The answer to your question is it depends on which fixtures you use & the current draw of each added up!!
LEDs draw WAY less current.
Also this site has tons of LED bulbs...... http://autolumination.com/
5.9Excursion
12-24-2007 09:54 AM
HOHN
10-18-2004 11:48 PM
